url-list
Creates a URL list and enters its configuration mode. URL
lists are a means of categorizing URLs on the basis of various criteria, such as frequently
used, not-permitted, etc. It is used in URL filters to identify whitelisted/blacklisted
URLs. Web requests are blocked or approved based on URL filter whitelist/blacklist rules. A
whitelist bans all sites except the categories and URL lists defined in the whitelist. The
blacklist allows all sites except the categories and URL lists defined in the
blacklist.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
url-list <URL-LIST-NAME>
Parameters
| <URL-LIST-NAME> |
- Specify the URL list
name. The URL list is created if another list with the same name does
not exist.
nx9500-6C8809(config)#url-list URLlist1
nx9500-6C8809(config-url-list-URLlist1)#?
URL List Mode commands:
description Description of the category
no Negate a command or set its defaults
url Add a URL entry
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
nx9500-6C8809(config-url-list-URLlist1)#url http://www.example_company.com depth 10
nx9500-6C8809(config-url-list-test)#show context
url-list test
Related Commands
| no |
Removes an existing URL list |
